http://bicycletutor.com
Fino, nema sta - majstor se bas trudi...
Evo i tema do sada postavljenih:
* How To Loosen a Stiff Chain Link
* How To Overhaul a Threaded Headset
* How To Adjust Your Seat Height and Angle
* How To Clean and Lubricate a Chain
* How To Replace a Freehub Body
* How To Overhaul Wheel Bearings
* How To Replace a Broken Spoke
* How To True a Wheel
* How To Check If Your Bearings Are Worn
* How To Lubricate Brake and Shift Cables
* How To Replace a Cartridge Bottom Bracket
* How To Replace Cotterless Crank Arms
* How To Remove and Install Your Wheels
* How To Fix a Flat Tire
* How To Replace Your Pedals
* How To Adjust Your Front Derailer
* How To Calculate Chain Length
* How To Replace a Cassette Cluster
* Why WD-40 is Bad for Your Bike Chain
* How To Adjust Your Rear Derailer
Fin sajt sa video uputstvima za odrzavanje MTB-a
